Driving in heavy rain no engine brake
Discussion in 'Questions From New Drivers' started by Chrissholt, Dec 3, 2014.
  1. Chrissholt
    Chrissholt Bobtail Member
    11
    Dec 3, 2014
    Ok thanks. Is there a way to kind of measure what gear I should be in? The largest hill I descend is on highway 1. The hill is only about a mile long. Not sure the grade but fairly steep. Well paved in town 2 lanes. Under normal circumstances I would usually start descending at 45mph in 10th gear with the engine brake on high and probably only brake 2-3 times before reaching the bottom at about 60 mph. Obviously this is going to be a lot different with the pouring rain we've had here lately. Would 9th gear be too high? I would start descending at 35mph? Seems awfully slow
  3. CJndaTruck
    CJndaTruck Road Train Member
    3,349
    3,365
    Nov 21, 2014
    Knoxville, TN (area)
    Well hwy 1 after yesterday shouldn't be so bad. It's that first rain you have to worry about really. 1 doesn't have an ice problem and a mile isn't a long hill. Yesterday I would have started a hill in those conditions really slow. Now you can almost take I like normal (it sounds like a daily hill for you). Just try and get that "it seems awfully slow" mentality out of your head. I don't know how many times ice been passed in bad weather just to watch the truck passing me drive right into a ditch. I'm sure the last thought they all had was "darn I shouldn't have tried to pass"
  4. Chrissholt
    11
    Dec 3, 2014
    Great. Thanks for all of your answers. Your right. 1 should be better. I night drive. Now that the worst weather is probably over I'm more curious on how I should drive in the future. My biggest concern isn't how slow I'm going. I do my best to be as safe as possible. I'll get there when I get there. I'm getting paid by the hour is my mentality. My concern is for other drivers who are still driving 60+mph through all of this rain and coming up to a truck doing 35. The dmv really needs to do a better job weeding out all of these unsafe drivers on the road who are driving their cars like it's sunny and dry outside.
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    If I'm descending a steep grade in slick conditions, whether rain on long dry roads or in snow, I'll use jakes but only apply them in low setting to begin with. What you DON'T want to do is put those jakes on high and then get off the throttle so they grab hard. I'll get off the throttle in low jake setting, THEN adjust the jakes to middle or high after they are fully engaged. Especially don't have the jakes on full and be constantly getting on and off the throttle.
    Regarding which gear to be in on the descent, I'll take one gear less than I normally take, starting down the hill a little slower and see if the low or medium jake settings will be enough to hold it. I dislike getting into high jake setting if possible and will downshift to get a gear I can control speed in low or medium jake if possible.
    Another thing is to be ready to instantly CANCEL the jake if you feel you are starting to slide or jackknife. Cancel the jake to let yourself correct, then get on the service brakes gradually to bring the speed back down and reengage jake in low setting.
  6. n3ss
    n3ss Heavy Load Member
    737
    340
    Nov 4, 2013
    LTL way: Hammer down, slam on the brakes at the last second, if you have to.
  7. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Not sure how you come to that amazing conclusion there chief.
    I said to use LOWER gears not higher. Get it yet? Want a picture?
    I regularly gross over 100,000lbs, and have done so for a couple of decades now, all without incident and in 19 different countries. So I think it's safe to say I may have an idea how to drive down a mountain pass. So go play with your little 80k lb setups then come back.
    Read what I posted completely and then try to come back with some witty remark.
    Martin
  8. n3ss
    737
    340
    Nov 4, 2013
    Not sure what you're going on about, aside from projecting your insecurities. i was joking about how "less than truckload"(LTL) drivers tend to pretty much do the opposite.
  9. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    No insecurities thank you, but a very long (one of "those" days) day and glancing at LTL thought LLT, meaning me.
    That being the case, I am not too proud to send my sincere apologies in your direction.
    Martin
  10. Passin Thru
    Passin Thru Road Train Member
    1,918
    566
    Mar 8, 2007
    VA
    We do what they do in China. Let it rain. Funny, trucks didn't have Jakees in the early 70s and we got along fine running NM, UT, CO, and KS. Those Kansas mountains were the worst but the wind came and blew them all away.
