Dry air from idling?
Discussion in 'Questions From New Drivers' started by TurtlesLikeI, Aug 16, 2019.
  1. TurtlesLikeI
    TurtlesLikeI Light Load Member
    238
    154
    Oct 13, 2015
    Nevada
    Wasn’t really sure where to put this. I’m having a not very fun issue. When trying to sleep, the air my sleeper is pumping out is so dry that it actually starts being painful to breathe in short order. If I manage to sleep, I wake up with painfully dry nose, sinuses and throat. This is with a seemingly useless humidifier running and keeping the AC pressure on low.
    Looking this up online, every mention of dry air seems to be related to running the heater in the winter... I’ve never had an issue like this before.
    Is there some kind of mechanical issue that would cause the AC to be near unbreathable dry air or is it just the result of Arizona and 100 degrees? I sleep during the day because of my schedule. Air quality is fine while driving
    FlaSwampRat Thanks this.
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    While it's not really a dry air thing but more of a air quality thing have you changed your cabin air filters recently?
    Lepton1 and Suspect Zero Thank this.
  4. Cattleman84
    Cattleman84 Road Train Member
    10,018
    71,542
    Nov 1, 2017
    The Sticks, Idaho
    A/C works by removing moisture from the air to no more than 16% humidity... Arizona probably doesn't have even that much moisture in the air to begin with... So dry hot air + A/C = really dry cool air.
  5. Ridgeline
    22,727
    123,473
    A/C takes any humidity out of the air. If there is hardly any air, it will remover a lot of it.
    As mentioned, start with the changing the filters.
    Also think about swamp cooler or mister to get some humidity up.
  6. tarmadilo
    tarmadilo Road Train Member
    1,731
    4,771
    Dec 12, 2018
    An easy humidifier: wet a towel and hang it up somewhere in the cab.
  7. TurtlesLikeI
    238
    154
    Oct 13, 2015
    Nevada
    Yeah, brand new filters
  8. TurtlesLikeI
    238
    154
    Oct 13, 2015
    Nevada
    Any suggestions on a swamp cooler? Could they realistically cool a sleeper sitting in 100+ weather?
  9. D.Tibbitt
    157,176
    Ill trade u. My arizona blood needs dry air. I will idle my truck even if it 55 degreees but humid. I dont do humidity.
  10. GreenPete359
    GreenPete359 Road Train Member
    2,255
    5,428
    Oct 21, 2017
    Driving my recliner
    Probably not cool it, but one would definitely add to you humidity level
    Edit: on 2nd thought. When i had to get a sleep apnea machine, it had a humidifier built into it. You have to add water to it every night. Maybe look into something like that.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Crack the windows to keep some fresh air in might help some.
    Sirscrapntruckalot and Opus Thank this.
