DT 12 Transmission.
Discussion in 'Freightliner Forum' started by Intothesunset, Aug 15, 2019.
  1. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    What is the cost of one of these new?
    It works okish in forward. But use it in reverse for 5 minutes and get overheat clutch warning. After 10 minutes it acts real sketchy. Great piece of trash transmission.
    Trucker61016, D.Tibbitt and mhyn Thank this.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Not sure of the cost but you definitely wanna be sitting down when you find out.
    D.Tibbitt and Intothesunset Thank this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    take it to detroit dealer. take with you $7k ... :)
    stwik, Trucker61016 and D.Tibbitt Thank this.
  5. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    It's a 30,000 mile truck. I hope it starts on fire.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Then it should be under warranty and only cost you downtime.
    stwik Thanks this.
  7. D.Tibbitt
    157,152
    Ive never got that in mine. It definatly has its quirks but i have backed down dirt road to deliveries for a couple miles amd it never say its hot
    Intothesunset and Trucker61016 Thank this.
  8. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    I must have a bad DT12 made on a Friday or something? Oh and it's about 100 degrees in Laredo, I was trying to back into an impossible spot unless I was the yard dog who did it frequently.
  9. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    If your heating the clutch up let it cool down. Make sure it's in first gear if doing a lot pull ups to get in dock or sliding the trailer tandems.
    It has a special downhill mode not everyone knows about. So it doesn't keep shifting gears or goes into E coast. You don't use the engine brake like older trucks on and off on and off going downhill. You turn it on and let it stay on level 1 2 or 3. The transmission will keep slowing down the truck and keep dropping gears. It never stops. So if you have stage 3 on, to stop it from droping gears you have to switch to stage 2 or 1.
    Stage 3 will ALWAYS keep the engine RPMs 1750-2200 and it will keep dropping gears to keep that range and keep giving you maximum braking power till you turn it off from 70MPH all the way down to 10MPH. What you really should to it watch the RPMs if the get to 1750 just flip to stage 2 and truck will stay in gear and start rolling faster. Then turn stage 3 on to slow down some.
    Stage 1 and 2 are like 1200-1750 RPMs. You can just turn on Descent Mode it will do it everything automatic and you just set the speed you want the truck to hold going downhill
    Intothesunset Thanks this.
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    What you just stated is true. I've been learning this. Yet it is the most uderly retarded truck I've ever drove.
  11. Brandt
    4,625
    6,359
    Sep 17, 2012
    To use Descent Mode you turn on cruise control. Then turn on Stage 1 engine brake. Then use the regular brake pedal and slow down to the speed drivers want the truck to go downhill. Here the trick part kinda. Once you get speed you want say 45 MPH. Take foot off the brakes and set the cruise control. This will make the engine brake stay in the current gear. If the truck start going faster, the computers will turn on stage 2 or 3. It also probably will downshift to bring engine RPMs up so you will have maximum engine brake power in stage 3 if that is need to hold the truck speed you set. This also will bypass the normal setting were cruise control will let truck roll 5 or 7 MPH over the set speed limit before engine brakes normal kick in.
    Flint1 and Intothesunset Thank this.
