DT12 Trans Drops into N when I come to a stop?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wombat63, May 9, 2024.
  1. Wombat63
    Wombat63 Light Load Member
    103
    64
    Nov 3, 2018
    I have a 2016 Wetsern Star, DD15 with a DT12 in it...
    Has been operating flawlessly, until a couple of weeks ago, I started getting overrevving between gears, not a constant issue but on upshifts it would ramp up between odd shifts, no issues on downshifts.
    A couple of weeks ago I had to come to a hard stop (Nashville, rush hour!) once I once stopped the trans went into N and beeped at me, I couldn't get it to go into gear, air pressure was perfect, the only remedy I could think of was shutting off the battery for a couple seconds and when I started the truck back up, it shifted perfectly, no issues again for the next 1500miles, the over revving did continue.
    Monday, when I was delivering my load, the trans shut down again and I repeated the process of powering off and it worked, this happened almost every time I came to a stop.
    I am completely at a loss as to what it could be and would really appreciate any help with the issue.
  3. FLHT
    FLHT Road Train Member
    1,486
    2,746
    Aug 2, 2014
    You got a sensor going bad.
    Any chance it was raining ?
  4. Wombat63
    103
    64
    Nov 3, 2018
    No not raining? which sensor do you have any idea? have you had this problem?
  5. Wombat63
    103
    64
    Nov 3, 2018
    I did have an idiot stereo guy try and fix my radio and he completely messed things up, but that was all in my overhead, he left bare wires cut and I couldn't get interior lights, lane departure, high beams, window power... any chance that he could have screwed up a sensor doing that?
  6. wichris
    wichris Road Train Member
    4,582
    9,462
    Jan 17, 2011
    Why not just plug in and see what the stored codes are?
    FLHT Thanks this.
  7. Wombat63
    103
    64
    Nov 3, 2018
    SPN 520970 FMI 7
  8. Brandt
    Brandt Road Train Member
    4,674
    6,477
    Sep 17, 2012
    When you say over revving maybe the clutch is slipping. I believe there is 750k warranty on the transmission but 350k on clutch.
  9. wichris
    4,582
    9,462
    Jan 17, 2011
    Pretty generic code for clutch. Plug in DDL to diagnose/repair.
  10. 813Trucker
    813Trucker Bobtail Member
    7
    I need help i have this code did you get it fixed if so what was the problem?
  11. 813Trucker
    7
    I have this same code did you get fixed? if so what was the problem?
