DT12 Transmission AG uses?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wauto, Jan 23, 2021.
  1. wauto
    wauto Bobtail Member
    Looking at buying a Cascadia with a dd13 and a dt12 transmission. I've been trucking for 30 plus years and am now partially handicapped. My question is. Does anybody have "real world" experience, pulling a loaded hopper trailer out of a field using this transmission? Also it's a direct drive dd12 with a 2.47 rear ratio.
  3. Hye
    Hye Bobtail Member
    46
    24
    Jan 23, 2021
    loaded hopper with Dd13 ? ))))
    you need a truck with dd16 engine and big rears(Meritor only)...
  4. AModelCat
    145,188
    DD16? That's a little overkill unless he's pulling a super b.
    The 2.47 rear ratio would be what would make me pass. Not a good ratio for heavy loads on soft ground IMO.
  5. uncleal13
    uncleal13 Road Train Member
    3,756
    6,193
    Apr 9, 2009
    Humboldt, Sk
    Not Freightliner, but our fleet had Volvos with iShift, pretty much has same first gear ratio of 11.78 and 3.42 rears. They couldn’t launch 140,000 lbs out of a soft field without getting a push. The newer ones with the crawler gear work good. The new Detroit HD transmission has better gearing.
    The direct drive does have a lower 1st gear than the over drive. About 14.94
    You might be okay at 80,000 but 2.79 would be better.
    there is a formula for startability to be certain.
    Hye and 25(2)+2 Thank this.
  6. wauto
    Thanks I'd be 80,000 and it's a dt12 hd. Maybe it would put up with it during harvest.
  7. Hye
    Hye Bobtail Member
    46
    24
    Jan 23, 2021
    What is happened to your cascadia with dd16 ultrashift ? Sold ?
  8. uncleal13
    3,756
    6,193
    Apr 9, 2009
    Humboldt, Sk
    I still own and operate it. The company has about half o/o’s and half drivers with Volvos and some Mack Anthems.
    Hye Thanks this.
