Dt12 transmission air problems
Discussion in 'Freightliner Forum' started by Mflegacy, Jan 19, 2023.
  1. Mflegacy
    Mflegacy Bobtail Member
    Jan 19, 2023
    Thanks Received:
    Hello. I have a 16 cascadia with dt12. Recently my truck started to rev when I would shift from even # gears to odd # gears. Ex 8-9 10-11. But doesn't rev when shifting from odd gears to even gears. Or even odd gears to odd gears. Any idea what this could be?
  2. Timm1q
    Timm1q Bobtail Member
    Mar 14, 2022
    11
    Thanks Received:
    Hi. The same. Did you resolve it?
    As for me - did already program update - no changes. Mechanic connected to truck and checked for faults - all is good.
    Why did you think that the problem is connected with air?
  3. NorCenArk
    NorCenArk Light Load Member
    Mar 31, 2011
    76
    Thanks Received:
    35
    Russellville, AR
    My 16 Western Star with DT12 is doing the same. A friend of mine has software for troubleshooting, we did a transmission and clutch relearn but it did not change anything. Next thing I will do is check wiring harness to TCM and pins to make sure there is no corrosion.
  4. NorCenArk
    Mar 31, 2011
    76
    Thanks Received:
    35
    Russellville, AR
    Did you ever get anything figured out on your transmission?
  5. SWM_TECH
    SWM_TECH Light Load Member
    Apr 15, 2018
    139
    Thanks Received:
    145
    For Engine RPM flare during up shifts, first you need to make sure you at least 100 psi air pressure to transmission and don't have air leaks. If you have air leaks fix before going on. Next do road test with Diagnostic Link log Actual Engine Speed, Countershaft Speed and Actual Gear engaged. After test drive you review the log file and if the engine speed flare is there. Next steps is to remove the transmission and rebuild the Counter shaft brake.
    QUALITYTRUCK Thanks this.
  6. SWM_TECH
    Apr 15, 2018
    139
    Thanks Received:
    145
    For those who are having the engine rev during up shifts I am attaching the diagnostics steps that the transmission manual says to do for engine rpm flare during up shifts. Seems like the diagnosis would be inexpensive. The cost would be in the repair.
    Timm1q, NorCenArk, Varga and 1 other person Thank this.
  7. NorCenArk
    Mar 31, 2011
    76
    Thanks Received:
    35
    Russellville, AR
    Thanks for responding, why would it only flare up on even to odd shifts and not odd to even shifts? Is there something in the transmission that controls only the even to odd shifts?
    Timm1q Thanks this.
  8. Mflegacy
    Jan 19, 2023
    Thanks Received:
    Thank you. After I originally posted this my problem went away. Now just recently it came back. Thank you for help
  9. Timm1q
    Mar 14, 2022
    11
    Thanks Received:
    Did you resolve the problem or still the same?
