DT12 Transmission Input shaft play
Discussion in 'Freightliner Forum' started by Scott Foster, Jun 27, 2024.
  1. Scott Foster
    Scott Foster Bobtail Member
    I run Deleted and we have always "cored" or sold to rebuilders any DT12 transmission that had ANY noticeable input shaft play. I am second guessing that now. I can't find any literature on how much input shaft paly is allowable or normal on a DT12. Thoughts, documents, links?
    Reason for edit: Removed business name and hyperlink
  3. Lockport
    Lockport Light Load Member
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    I recently replaced mine and as I understood it NO play is the allowable limit.
  4. Freddy2times
    Freddy2times Light Load Member
    64
    31
    Feb 12, 2019
    I can confirm, that the preload on that bearing in the transmission is so tight there is supposed to be 0 play. If you can wiggle the shaft your trans is toast. Rebuild or replace. Info on dtna freightliner.
  5. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,236
    Sep 27, 2015
    If you had a Volvo, you could make the shaft dance around. Long as it isn't leaking any fluid, Volvo say's it's a-o-kay.
