DT466 ICP issue
Discussion in 'International Forum' started by DDunphy, Nov 8, 2021.
  1. DDunphy
    DDunphy Bobtail Member
    Have a DT466 non EGR which is demanding 3300PSI under load but won’t build more than 2500-2600. IPR % sits at 65.04% constant under load.
    New IPR, ICP, HPOP, injector seals, ECM, Engine harness.
    Truck starts fine hot/cold but while under full load spits and sputters and won’t build the pressure it needs. Pump has been bench tested, and the IPR is getting 12.3v. Grounds checked.
    Out of ideas if anybody has any suggestions. Thanks!
  3. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Injectors themselves would be suspect at this point. Unplug all injectors and crank, check for leaks between injectors and the rail.
  4. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    Have you replaced the injection pressure sensor?
    What is the last 8 of the VIN?
