dt466 maxx force draining batt on start up
Discussion in 'International Forum' started by Michaelonega, Nov 29, 2021.
  1. Michaelonega
    Michaelonega Bobtail Member
    new battery's
    fully charged
    when i try to start it battery drains in less than 5 seconds any ideas
  3. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Either something is hooked up wrong or your starter if drawing a ton of amperage.
    Heavyd and Michaelonega Thank this.
  4. Michaelonega
    went to try earlier and now i just get a clicking from electrical panel on side of the bus
  5. AModelCat
    165,532
    Sure its not poor connections making it seem like weak batteries? Maybe starter on its way out?
    The amount of amperage draw on the batteries required to kill them in 5 seconds or less will definitely be melting the cables and other wiring.
    Flint1 Thanks this.
  6. Flint1
    Flint1 Road Train Member
    1,164
    9,969
    Sep 4, 2019
    Alberta
    Most of the positive and negative battery to vehicle connections are done at the starter on those. Make sure the group of positive and group of negative cables are tight on their studs on the starter.
    There is also a harness in the battery box, with 3 small fuse holders in them. Those fuse holder love to melt. Remove each fuse and check for a burnt terminal.
    That harness has 2 connectors near the starter. The terminals on those like to turn black and burn.
    Sounds like a poor connection, as others have stated in order to kill a battery that fast, there would be melting involved.
    Have you checked battery voltage with a meter? Or assuming they are dead because of no action?
    AModelCat Thanks this.
