Dt466 vs dt466E
Discussion in 'Ask An Owner Operator' started by Boss6147, Jul 25, 2023.
  1. Boss6147
    Boss6147 Bobtail Member
    Are these engines interchangeable? If my truck has a dt466 in it, can it be replaced with a dt466E?
  3. Star Rider
    Star Rider Road Train Member
    1,787
    18,592
    Sep 23, 2019
    Anything is possible, just depends on how deep your pockets are.
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,402
    7,947
    Jul 11, 2012
    in the bush somewhere
    I'm not positive but I'm reasonably certain the 466 is a mechanical fuel pump and the 466e is electronic. Meaning you'd need an ecm and appropriate wiring harnesses. Won't be too easy or cheap
  5. Lazer
    Lazer Road Train Member
    1,849
    2,983
    Jan 22, 2017
    I know a 466B will bolt in where a 466A was, but that was 20+ years ago.
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    DT 466 A & B were fully mechanical, while the E series is full electronic, including most dash gauges.
    It may can be done, but I wouldn't try it, even with a donor truck, because the wiring nightmare.
    Anyway, a 466 B is a much better engine that is easily turned up, and will give less problems and last longer than early E series engines.
  7. MacLean
    MacLean Road Train Member
    1,380
    4,092
    Sep 12, 2017
    Probably easier to make the electronic engine mechanical.
  8. Boss6147
    How can you tell if you have a dt466 or a dt466E?
  9. AModelCat
    164,667
    Most likely by looking at the fuel pump.
  10. MacLean
    1,380
    4,092
    Sep 12, 2017
  11. Sons Hero
    Sons Hero Road Train Member
    3,038
    31,147
    Jan 8, 2021
    Indiana
    We had several single axle dump trucks with dt466 mechanicals in, and 1 with a dt 466E. Stick with the mechanical, if it’s blown, they are cheap to overhaul. And they are peppier than an E.
