Dt466e dropping cylinders
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Fznh2o, Jan 24, 2020.
  1. Fznh2o
    Fznh2o Bobtail Member
    Need a little help. I have a 98 dt466e that when it warms up it drop 1 2 and 3 cylinders. Only does it after running 15-20 minutes. Already replaced IDM , Oil pump and fuel pressure is aound 50 psi. Only does it once it heats up. Oh and it all started at once. Any ideas.
    Thanks
  3. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    You need to figure out which one it drop first and go from there, probably wiring issue to that injector or the injector itself.
  4. Fznh2o
    They all drop at once. Turn off the truck and let it set for a few minutes it runs fine and then drop again.
  5. Heavyd
    Heavyd Road Train Member
    7,786
    6,223
    Feb 4, 2009
    Probably a shorted injector coil that needs a certain temp to fail at. ECM cannot pinpoint which one, so kills the bank, (1, 2 and 3).
  6. Raffito
    84
    53
    Aug 25, 2019
    Ingram, TX
    You need to have a scanner hook up and monitor diagnostic code at the time of drop off. It will show which injector first than will shows all three. That why you will know which one the replace.
  7. Fznh2o
    Gonna pass this on but the shop was saying it didn't show 1 individual injector dropping it's the whole bank at once. This is a 96 model idk if it shows individual injectors. I do know when it's hooked up to the laptop you can't cut off each injector like you can on the later engines. It only let's you do bank 1 or 2.
  8. Raffito
    84
    53
    Aug 25, 2019
    Ingram, TX
    One thing you can do is measure injector coils resistance when engine is cold. (I would measure all injector at valve cover). And again when at operating temp. or when injector dropping. If any injector is measuring more than that you need to inspect injector harness under valve cover and measure injector directly.
