DT466E HPOP removal
Discussion in 'International Forum' started by 4x4_Welder, Jan 6, 2016.
  1. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    I had an HPOP failure on an International DT466E, and only took a quick look at it but it looks like the timing cover comes off to change the pump. Is this right or am I missing something? I am trying to build a proper quote for the customer. Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Nope. It unbolts from the rear. Two bolts, takes 10mm socket. They are hard to find, hiding.
  4. 4x4_Welder
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Thanks, that's what I thought it should be but was rushing in the dark.
  5. Itow93
    Itow93 Bobtail Member
    4
    Feb 16, 2020
    Hello what year is yours
    I have a 97 I need to remove the HPOP as well
  6. Heavyd
    7,830
    6,282
    Feb 4, 2009
    It will be very similar.
  7. Itow93
    4
    Feb 16, 2020
    Hello how do you remove the fuel line from the pump
  8. Heavyd
    7,830
    6,282
    Feb 4, 2009
    Just a 3/4 wrench for those.
  9. Itow93
    4
    Feb 16, 2020
    Sweet I haven't been able to find the gaskets for it . Do you happen to know the type of gaskets ia need it to mount it back to the engine
  10. Heavyd
    7,830
    6,282
    Feb 4, 2009
    It's a sleeve style oring. 1812348C1 are the part numbers.
    Itow93 Thanks this.
  11. Itow93
    4
    Feb 16, 2020
    Thanks so Much. I have striped the threat from one of the mount bolts it leaking from it bad. I haven't done a helicoil because I don't have the right gaskets for the job . I been looking around you been only one that's has helped .
    Heavyd Thanks this.
