DT570 with DTC 525 & 534
Discussion in 'International Forum' started by eng.moh.4u, Oct 27, 2019.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    I have International Truck 7500 model 2006. The amber engine is shown and the truck cranking but not starting. The engine give errors 525 & 534 active and 451 to 456 inactive.
    Is that means that I have to replace the IDM.
  3. Heavyd
    Heavyd Road Train Member
    7,759
    6,199
    Feb 4, 2009
    525 is usually the code when the IDM is dead.
    eng.moh.4u Thanks this.
  4. eng.moh.4u
    40
    4
    Jan 13, 2017
    Thank you I found short on the IDM relay connection 86
    But also I have 422 & 425 with hard starting in the manual it indicates a harness or coil is open.
    Or is it a bad injector
  5. Heavyd
    7,759
    6,199
    Feb 4, 2009
    Injector coil resistance is 1.5 ohms +/- 0.5 ohms. So you need to test the injector coil to see if its bad or not.
  6. eng.moh.4u
    40
    4
    Jan 13, 2017
    After Testing the X1–6 to X1–24 found it was 4.5 ohm but when tested X1-6 to C it was less than 1.5 ohm and C to D at cylinder head cover injector connector got also less than 1.5 ohm. Same also with injector No 5 at closed coil power.
    I don't know where the deference in resistance went.
