dual fuel line mod
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JAnderson, Feb 13, 2012.
  1. JAnderson
    JAnderson Bobtail Member
    6
    okay guys i know this has probably been posted a million times, but can someone tell me where to T into the fuel line and where to run the front fuel line, and post pictures of what you did, and did you run larger fuel line from the tanks also?
  3. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    There is a port on the side of the housing that the fuel solenoid is bolted too, that is where you will tie into the feed at, to see where you need to go on the front head just look at how it is on the back. Follow the current line to the head and see which port it goes in, I believe it is the top, then you will have to pull that plug on the front, you may even have to move your fan bracket.
    I don't have pics and I'm not anywhere that I can get them either. Sorry.
