Dual screws single drive load transfer question.
Discussion in 'Ask An Owner Operator' started by feldsforever, Feb 10, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    The the truck is a 2016 cascadia.
    It seems at almost every stop dry ground or not. Empty or at gross, slow or angry driving. The drive will spin in every single oppertunity to leave a dead stop.
    When this happens I get a sequence of statements. 1) wheel spin detected then 2) reduce throttle 3) load transfer.
    This morning in slush . Leaving the T.A in new parris ohio.
    Just past the empty parking cop shack she preceded to spin and threw out sequence 1 and 2 but not three.
    I backed up about 4 feet and then ever so slowly started again up the ramp to exit. Once on the flat slight down grade I went to shut the load transfer off. But it hit me It wasn't on. I thought well that's weird. But preceded about my day.
    The L/T shuts off automatically at 45, or can be manually disengaged. Twice today I expected to have to turn it off or on and I did not.
    Thinking I'm crazy I just did a small soft spin in the mud. Sequence one and two appeared but not #3. When I tried the button it did not move air to the front bags from the back bags. I.e it did not work.
    I don't know anything about this. Nor do I know how to even begin to find the problem any suggestions would be a huge help.
    What I do know is the raising and lowering of the rear suspension is working correctly. But the "check ecas" light is on with no codes. I don't know of there is a relation
    Reason for edit: Grammer. Spelling. Punctuaction.
  3. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Mr @Misesian knows a lot about this stuff. He may be able to help.
  4. 201
    201 Road Train Member
    12,787
    26,309
    Apr 16, 2014
    high plains colorado
    I think it's the "traction control". I drove a newer KW that had that, it was a PITA. A wheel would drop from the air ride, the sensor detected a wheel spin, and applies the brakes. Stuff like that would drive me nuts with a newer truck.
    TripleSix, feldsforever and Bean Jr. Thank this.
  5. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    If your check ECAS light is on, the system may not be working. Freightliner uses MeritorWabco ECAS. One of my trucks is 2016 Freightliner 6x2. It’s supposed to engage in its own up to 40 mph. You can engage it by hitting the load transfer switch, and disengage by holding it down for 3 seconds.
    When I spec’d my International, I did not request the load transfer system, my fault. But, what I did was order all the parts of that system that I needed to complete it, and added a manual switch on the dash to operate it, no electronics doing it. You already have all the parts. You could have the dealer go into your ABS ECU and turn the feature off completely, the truck will think it’s no longer there, and add a switch on your dash that uses a simple fan solenoid to turn it on and off. You would be dumping your rear axle only, using the existing high capacity valves. That’s what I’m driving every day and I have no problems with it.
    feldsforever and BoxCarKidd Thank this.
  6. Misesian
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    An example. A couple weeks ago I was in Utica, NY and had to go Rochester and Syracuse. A storm blew through and dumped a lot of snow in only a couple hours. The roads weren’t perfect to begin with either. The way I took back to the interstate was a county road. It hadn’t been touched. All you could see was the poles telling you where the edge was. It has 4 grades on it that are short but steep. On the hills, I’d dump my tag and go right up without losing traction a bit. The pickup truck behind me, not so much, he kept spinning out going up the hills.
    The only time I’ve been stuck with the 6x2 was when I parked one night and didn’t pay attention. I woke up in the morning and I had sunk about 10 inches into thick mud and couldn’t get out. I was bobtail, a small wrecker for cars came out and winched next out.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Sorry I just skimmed your response. I will read it fully sometime around 3 am.
    The load transfer is not engaging, is that why the ecas light is on?
  8. Misesian
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    Yes. It could be the load transfer feature and components or another ABS fault not letting the system operate. ECAS is your ABS ECU from Meritor, of which the load transfer is a feature in the ECU.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thats cool, I can hit the button while in motion?
  10. Misesian
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    Yes. You can engage it manually at any time, disengage bu holding it down three seconds.
    feldsforever Thanks this.
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
    That's really good to know. I thought once it automatically shut off at 40. I was thinking it was limited to that speed.
    Where can I start to look for the problem, or where to start to diagnose it?
    Thanks in advance
