Dumb question dont get mad at me
Discussion in 'Ask An Owner Operator' started by TruckRunner, Jul 25, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    While looking at trucks for sale and it shows trucks with 40,000 rear axle weight and some with 38,000 axle weight, that kinda confuses me since we are only allowed 34,000 per axle with a non oversized load correct? So is the rear axle weight only for guys that haul oversized loads? I just plan to haul a regular trailer and I see a truck with a 38,000 axle weight so I wonder what that really means. Thanks.
    Oldironfan Thanks this.
  3. Dan47
    Dan47 Light Load Member
    91
    41
    Feb 14, 2015
    You can have up to 38k and be safe, however that does not mean you are legal (if you are licensed for 34).
    aussiejosh and TruckRunner Thank this.
  4. Allow Me.
    10,779
    12,630
    May 28, 2009
    Rancho Mirage, Ca.
    Yes you are allowed 34k, The axle rating you are talking about is just that, the rating you could haul before anything breaks, in theory. The manufacturer states "you can haul up to 40k or 38k with no problems. That's why heavy haul trucks have 3 axles generally because they haul more weight. The difference is heavier springs/suspension. Just like the difference between a F150 Ford and a F250. (I/2 ton VS.3/4 ton) Just heavier suspension springs shocks etc on the 3/4 ton and tires too.
  5. AUfan78
    AUfan78 Light Load Member
    136
    211
    Feb 13, 2018
    Mobile, Alabama
    Can't say about the 38k to 40k difference but 46k and heavier have larger heavier duty components to take the heavier load without wearing out as fast as the lighter components would.
    bzinger and TruckRunner Thank this.
  6. gentleroger
    gentleroger Road Train Member
    7,942
    21,754
    Jun 1, 2010
    While you are limited to 34k running down the road - what about when you are at the customer and they want the tandems all the way back? You can easily hit 38-40k then. You want the axle to be able to withstand normal usage.
    TruckRunner Thanks this.
  7. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    There's a significant difference between 1/2 ton axles and 3/4 ton axles, and that goes beyond suspension and tires. I've never seen full floating axles in a 1/2 ton, nor have I ever seen weight bearing axles in a 3/4 ton.
    A better comparison might be in the 3/4 ton vs 1 ton. Heavier rated axles are going to have beefier bearings to handle the weight, brakes might be bigger to stop the weight, as well as the suspension and tire ratings.
    TripleSix Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    38 and 40 k axles are standard highway axles, I don’t think anyone actually makes a 34,000 lbs axle. Up here in Canada we run 37,400 lbs all the time on the same axles.
    Generally, even heavy haul still only has the same weights on the drive axles (certainly could be more with the right permits) it’s just that they are pulling a lot more weight. While technically a 38 or 40 k axle can handle the weight placed on it, it is still only rated up to a certain gross combination weight for total lbs being pulled.
    A 46k or even 58k axle can pull a lot more weight with out burning up. Dragging all that weight makes a lot of heat.
  9. TripleSix
    133,641
    Winner. Beefier axles have beefier wheel bearings, axles and ring gear.
    For the most part, most of you wouldn't ever have any issues with the 38k rears. But if you have 1.) Big Power 2.) Bigger than 80k loads on a regular basis 3.) Lot's and lots of big hills to pull, you can easily cook the rear diffs. I always recommend that instead of buying old fleet trucks (only fleet trucks even have 38k rears), to instead buy an owner op spec'd truck with the full gauge package. An owner op truck will have things like a PYROMETER (monitors exhaust temp), engine oil temp sensor, transmission temp sensors and two rear axle temp sensors. These things will let you know if you need to back out of it, or even pull over to cool off BEFORE any parts grenade, saving you huge roadside repair/towing bills.
  10. ncmickey
    ncmickey Road Train Member
    3,863
    7,312
    Jun 21, 2013
    Durham NC
    In NC... you can have up to 38,000 on your drives or tandems. But your still restricted to 80,000 total
  11. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    34K on close spaced tandems is only the common denominator. That's what's legal in ALL states. Many states allow more. I guess you haven't purchased a RM motor carrier road atlas and educated yourself regarding the legal size / weight limits for the states you operate in?
