Dump truck engine idling question
Discussion in 'Questions From New Drivers' started by Sturgill, Feb 27, 2020.
  1. Sturgill
    Sturgill Bobtail Member
    16
    8
    Feb 27, 2020
    Hello, first post here. Been doing lots of research on getting a tri axle dump for Asphalt/gravel/sand hauling. For engine type I have read a lot of reviews on here. The biggest issue seem to be not letting the engine idol a lot because of the emissions crap. How do you Asphalt guys deal with the idol time when waiting to dump or while dumping? Or is it not that big of a issue? Thanks for any info. I’m leaning towards Cummins or DD. It will be newer 2014-2016 model truck. Thanks again for any input.
  3. Sumtinlidat
    Sumtinlidat Light Load Member
    139
    435
    Dec 17, 2017
    Las Vegas Nevada
    2018 X15 565-2050
    114,073 miles at the moment
    Idle 50% of my day. In town Vegas mostly. Occasionally out of state work/drives
    Just open it up on occasion to let her breath. Has never had to manually regen yet. EGT will get hot and burn out on her own during stand by at jobsites.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    We pretty much idle all day with several rare exceptions. On really BIG jobs the dump becomes a tanker with 300 gallons of fuel for backhoe, paver, bobcat etc. Otherwise it's driven enough so that it does not suffer much.
    This is for a 1980's era Superliner 500. No emissions anything in sight. Its been retired for over 5 years now sitting quietly in the barn.
  5. AModelCat
    165,057
    Can't just shut it off?
    If you're just running a straight truck, why not spec a smaller displacement engine? The smaller engine is going to have to work harder and build more heat.
