Dump truck O/OP
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by biggi1996, Jan 10, 2018.
  1. biggi1996
    biggi1996 Light Load Member
    120
    13
    Dec 10, 2014
    What is needed to run a dump truck local in Houston, Texas?
  3. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
  4. biggi1996
    120
    13
    Dec 10, 2014
  5. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
  6. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    I would contact local outfits, construction and such. Some will lease you on or would be willing to use your services if you have your own authority. That is where I would start. I was looking into getting a dump, and that is where I started up here in Detroit. I stuck with automotive, the dump guys still call to see if I am available.
  7. biggi1996
    120
    13
    Dec 10, 2014
    Thanks Justrucking2
  8. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    What are you doing now? Are you in that field as say a driver? If so, I am sure you work with or around other dump/construction outfits. I would ask around and pick some brains. I have a friend up in VA that owns his own dump, he is doing pretty good from the sounds of it.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Don't you mean a truck with some way to dump???? :)
  10. snowwy
    20,612
    13,333
    Jul 6, 2009
    As far as i know. A truck and your own authority. And some connections.
    In utah. There used to be a broker. Don't know how it's done these days since the recession. I see a lot of new companies since i hauled dirt. And a lot of old companies that disappeared.
  11. OldRed98
    OldRed98 Medium Load Member
    308
    251
    Apr 18, 2017
    Colorado
    I know around here (in Colorado) there are a couple of brokers that will help you with loads. My buddy is running a straight body dump and making good money. He said $70-$75 an hour. I know Houston has a lot of work from the hurricane clean up. I had a call from a broker and I think it was paying around $60/hr for belly dump.
    You will need your own authority and insurance with a 750K general liability... I am a private hauler right now but I looked into getting my own authority with how strong dump rates are right now.
