Dump trucking questions
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by NEKTrk4L, Feb 22, 2019.
  1. NEKTrk4L
    NEKTrk4L Bobtail Member
    10
    I'm in the process of buying a dump truck and going out on my own. I don't currently drive a truck, but have about 4 years experience in the past 6 years driving straight flatbeds, concrete mixers, end dumps and dump trucks, and hauling grain. One of the guys I used to work for driving a dump truck has agreed to hire me out as an owner-operator once I get rolling. He has about 40 trucks of his own in the KC area. He has the exclusive contract for one asphalt plant and one quarry, in addition to contracts with at least 3 other quarries. Having worked for him in the past and seeing how busy they are, I have no worries about staying busy, at least from March through early December.
    I plan to buy a KW or Pete quad-axle that will legally haul 19-20 tons in Kansas and this will be all intrastate operations. I also won't buy anything that doesn't have a CAT or Cummins and want an 07 or older so I don't have any EGR or DEF. Asphalt pays $97/hr for a quad axle and 0-10 mile hauls out of the quarry pays $4.50/ton. He will take 10% of the hourly or per ton rate for brokering the loads.
    So here's where I need a bit of guidance... I'm unable to leave my current job and get this going until August and I want to make sure my timeline and process to get to that point makes sense.. So my biggest question is: how is the buyers market for dump trucks right now? Am I better off to buy a good truck that meets my perameters when I come across one and just let it sit for a few months until I can get rolling? Or wait until I leave my current job and hope I can find a good truck quickly? We have plenty of money to make the payments if we buy a truck sooner, so that's not an issue. Just looking for advice on how likely I am to find a good quad-axle in my less than 60k price range in a short amount of time if I wait?
  3. fss99701
    fss99701 Medium Load Member
    327
    663
    Feb 14, 2019
    none of your business
    Cat or Cummins? I would definitely go with a caterpillar I really miss those engines.
    I've drove many C,15 and I think it's one of the best engines ever made, heads and shoulders above any X15.
    A buddy of mine told me that the new Detroit engines are pretty good have no experience with them the dd16 and dd15.
    Grubby Thanks this.
  4. NEKTrk4L
    10
    Haven't seen very many available with a C15, most C12 or C13. Cummins generally has a longer lifespan before needing an in-frame and a bit cheaper to work on sometimes. Those are my main reasons in leaning that direction.
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    It’s very hard to find a good used truck. Why, in the dump truck bussiness, the trucks get ran hard and go through hell. Most the time when someone lets a truck go, they don’t have the time or patience to keep up on the work of the truck anymore and sometimes the truck needs too many repairs. Doesn’t mean the truck isn’t worth the asking price at all and still can be a great truck. But if you think the truck is just going to be turn key and not need repairs for first year, you will be in for a surprise. You absolutely need to know a little bit about how to work on a truck. So if you don’t, be prepared to learn on a whim. Paying a shop to do these repairs will cost you more money than you could imagine.
    I started my dump truck bussiness a year ago and left my job to do it. I too was guaranteed work. In my state we only need one lift axle to haul 23 and half ton. 73280k gross. Depends on truck weight obviously. I bought a old 379 with c12 but had it tuned to push over 500hp through and 18 speed. From March of last year to novenmber, I made a little over 150k working 8 hour days 5-6 days a week. A few 10 hour days. With an old truck, comes repairs. However, old trucks don’t usually leave you dead in the water like a new one will with some silly derate mode or sensor failure. I invested money into big air tools and big shop air compressor. I spent a lot of time over the winter fixing little things as I saw as potential problems like worn out slack adjusters and such. YouTube can teach you all that. Also bought cat service manual and parts manual on cd to diagnose and do repairs. Tracked down every oil leak and painted motor.
    Moral of the story, when you shut the truck off at night, it’s time to work on it. Or don’t work on it. I run with some guys that have some real piece of junk and hazard to road and just pocket the money.
    As far the job goes, I love this bussiness and wouldn’t dream of doing anything else. Fun stuff, home every night. Days are short and only travel with 10-20 miles usually.
    bgreyhart, Lav-25, Badmon and 3 others Thank this.
  6. NEKTrk4L
    10
    Thanks for the reply! Your revenue match up pretty closely to what I've estimated. What have your total expenses been this first year? My numbers came in around 65k/yr in expenses.. this includes repairs, preventative maintence, fuel for about 45,000 miles, insurance, tires, and plates/usage taxes. Could be slightly higher the first year depending on what the truck needs to be road ready.
    Been looking at trucks in the 30-50k range mostly and trying to find one that has fairly low miles on a rebuild. How tough of a time did you have finding the right truck?
    Kansas follows the federal bridge table so a quad-axle with say a 23ft outer bridge can gross 62,500. Depending on truck weight that should allow 19-21 tons.
  7. fss99701
    327
    663
    Feb 14, 2019
    I don't really know about dump trucks I know up here we use a lot of 15 liter engines but I'm always hearing people saying that Cummings are crap. Before everybody tries to hang me that's just what I hear from all the mechanics that I know.
    Anyways good luck finding something that's not totally trashed out.
  8. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    A good way to buy a used dump is to go to equipment auctions.When contractors finish a large job they usually sell off their surplus equipment.If you know what you're looking at you can get a good deal. Where I live they have a truck paper TNT(truck n trailer) it lists all the auctions in the area.
    fss99701 Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I cannot offer the opinion on engine, my dump truck work featured a V format engine rather than a inline. Which is essentially it's own class. It was a good engine. And that might have been a understatement.
    If you find a older cat, grab it. But keep in mind CAT quit making highway engines totally because they cannot get good emissions. It will be harder and harder to get a good Cat as the years go by. Detriot would be my second choice.Cummins? Eh...it will take too long to "Wake up" you want a engine that is rather agile in the lower RPM's
  10. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    My opinion would be if you are looking for a dump truck that's going to be in good shape that's usable that you don't pay top dollar for you need to start looking immediately.
    You're going to find that there are all kinds of trucks for sale but you'll find they need a lot of work or they're worn out or they have some kind of a problem or something to that effect or they're very beat up Etc. Dump trucks take a terrible beating.
    Either that or you'll find what you're looking for but it would be at a dealership somewhere for top top dollar. I would start searching for owner operators that are retiring and keep your eyes open and look and look and look to find something good. If you have the money that you can make the payments in the meantime that's great.
    If you start looking for a truck around the time you need a truck, you surely are going to spend more than you should be
  11. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I know I'm going to get a lot of flack about this, but for dump work, nothing works harder, longer and takes a beating like a Mack. When they're loaded they are sweet, when they're empty It's like driving a brick. T800's make nice dumps also.
