Dump valve question
Discussion in 'Flatbed Trucking Forum' started by insanityeight, Sep 29, 2018.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    Which axle is best for the dump valve on a 53x102 mac flatbed and would a lift axle be better. Thanks in advance. Happy trucking
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Lift axle only make sense if you have long deadhead legs or toll considerations. On a big spread tandem a dump valve on both axles might be your best option. You’ll still need to be able to dump both sometimes for unloading heavy pieces or unhooking and that would let you choose which axle to dump when dumping one.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Use rear axle dump, ft. axle lift
  5. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    It already has the double axle dump so i need a seperate single rear axle to go with it for tight turns and backing
    baha Thanks this.
  6. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    Ideally, you should be able to dump either axle at will. Sometimes you'll want use the front. Sometimes you may use the rear. However, if I had to pick just one it would be the rear axle.
    insanityeight Thanks this.
  7. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Would not both axles dump by pulling red parking valve or are older trailers not the same that way
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    The company I drove for had their trailer setup that way. It was kinda a PITA when you were at a dock and wanted to have the air out anyway. The airbags would deflate and the trailer shift forward from the change in the suspension. you would end up 1-1/2' away from the dock when the are was finally out. Then you wanted to release the brakes and back up against the dock and the air bags would start filling up again. :D
  9. DSK333
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    They don't have to be set up that way. Alternatively, you can have them on individual manually switched solenoids wired to the dash.
  10. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Dumping the rear might be easier if the trailer is empty or really light. Dumping the back with a 45,000lb coil parked in the middle of the trailer could be interesting.
  11. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    So do you suggest dumping the front with a coil??
