Eastern PA LTL
Discussion in 'LTL and Local Delivery Trucking Forum' started by tallguy66, Aug 9, 2020.
  1. tallguy66
    tallguy66 Medium Load Member
    534
    873
    Oct 18, 2018
    Anyone from Allentown(ABE) on here doing LTL? Where do your routes take you?
    Also those that run the I-80 toll road, where are you from?
    Thanks for any info.
  3. MACK E-6
    50,023
    238,226
    What I-80 toll road?
    LtlAnonymous Thanks this.
  4. tallguy66
    534
    873
    Oct 18, 2018
    i80 through Ohio and Indiana
  5. Old_n_gray
    Old_n_gray Road Train Member
    1,229
    4,251
    Apr 9, 2016
    western pa
    Saia YRC Old Dominion and ABF hiring out of Carlisle.
  6. tallguy66
    534
    873
    Oct 18, 2018
    I was looking more up in the Allentown area. Those companies are also hiring over by me, except for ABF which I haven’t seen around. Just wondering where the Allentown Linehaul drivers run.
  7. jmz
    jmz Road Train Member
    1,211
    2,861
    Mar 9, 2018
    Great Plains
    Most LTL companies have a hub/breakbulk in the Harrisburg/Carlisle area so I’d say it’s a safe bet that you’ll be running there to start out.
  8. tallguy66
    534
    873
    Oct 18, 2018
    I thought that might be a common route. I know SAIA has a terminal near me, and a bigger one about 80 miles away.. I wonder if that’s a bad thing. Same with Odfl they got two terminals at the exact same location.
    Are doubles usually loaded near gross? I always see LTL guys doing pretty well in the hills of PA while I’m at 50 mph by the top of each little hill
  9. MACK E-6
    50,023
    238,226
    That’s hard to say. It depends on the company’s accounts.
    If they haul a lot of things like tile and chemicals, then linehaul loads will tend toward the heavier side.
    jmz and tallguy66 Thank this.
  10. jmz
    1,211
    2,861
    Mar 9, 2018
    Great Plains
    Also depends on where it’s going. I’ve noticed a lot of FxF barns that cover rural areas have heavy trailers with stuff like seed and pesticides for farmers, and bulk chemicals and heavy plastic packaging for meat packing plants.
    McUzi, tallguy66 and MACK E-6 Thank this.
  11. LTLTRKR
    LTLTRKR Bobtail Member
    15
    15
    Apr 6, 2020
    Pyle runs all 53' Ft with no doubles, from Allentown we run the Northeast as it is centrally located
