Hi I have a 2019 sd122 corando
I’m trying to hook up easy jake but having some issues
My switch is 2 stage high and low
When I have it hooked up on easy jake switch I can only get low side of exhaust brake any help would be great if anyone knows what might be wrong
Easy jake hook up on 2019 coranado
Discussion in 'Freightliner Forum' started by Rush011, Apr 15, 2020.
I hooked mine up to the clutch switch.
Doing it this way it doesn’t effect my two stage jake at all. -
Thanks for the reply I got it figured out
I might try the clutch though if I have problems
Thanks againHulld Thanks this. -
Glad you got it figured out.
I have found the clutch switch to be the easiest and cleanest way of wiring it up.
You also get the added benefit of the easy jake switch also becoming a cruise control cancel switch when hooked in to the clutch switch.
Works quite nice when rolling up on traffic when cruise is on.
Reach over shut switch off cruise is canceled turn back on jake on.
I also mounted mine so the button is to the left of the shifter and is activated with my thumb.
