Eatin autoshift very hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Helowrenchturn2, Mar 23, 2015.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Been having a bad knock (for lack of a better word). Was thinking engine mounts. Crawled under just now to check things out and found the transmission very very hot to the touch. I'm thinking bearings going bad. What say you?
  3. Heavyd
    Heavyd Road Train Member
    7,836
    6,289
    Feb 4, 2009
    How is the oil level?
  4. Helowrenchturn2
    484
    140
    Apr 23, 2013
    To the top of the fill hole
  5. d60-14
    d60-14 Light Load Member
    72
    30
    May 23, 2012
    Measure the temperature of transmission oil after a long run, it should be no more than 200-220 F. Make sure you using the right oil for this box. It is a synthetic SAE 50 Long Life. If you running at 250 F all the time, you will destroy all the parts inside.
  6. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    Just because you think it's hot to the touch doesn't mean much. You can't hold your hand on something that's 140 degrees. If you throw a cup of water on it, and it doesn't sizzle (like touching your finger to your tongue and then touching the surface of an iron to see if it's hot) then it's not too hot. It should have a temperature gauge in the truck, but normal operating temps are probably 180 to 205 and up into the 220 or 230 range if you're working it hard.
    Heavyd Thanks this.
  7. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    My transmission temp never goes above 200 it stays around 150-180 unless im having to shift alot
