Eaton 10 speed Trans failure?
Discussion in 'Ask An Owner Operator' started by ChevyCam, Jul 17, 2020.
  1. ChevyCam
    ChevyCam Light Load Member
    269
    402
    Mar 4, 2018
    I was loaded heavy today on 500 miles. On the last leg started to get a clunk type noise from the transmission after a few miles of stop and go traffic. When the clunk would happen I could feel it in the shifter.
    Pulled over, checked driveline, rears, carrier bearing nothing looked out of place. It felt almost as if the crossmember was loose and the trans was jumping almost. Once I got back rolling I noticed that the clunk noise sounded almost like the transmission was trying to drop into low range.
    The noise was non existent when coasting in gear at highway speeds or coasting with clutch depressed. Anything above 1/4 throttle the problem would comeback. I managed to drop my load after some careful highway driving.
    Once I bobtailed to the house the problem was completely gone. Shifts were smooth, no funny noises or knocks nothing abnormal. The noise is loud and sounds like something was about to grenade. Any thoughts? Trans is a RTO16210c / 96' 9400
  3. DUNE-T
    DUNE-T Road Train Member
    7,078
    17,256
    May 10, 2015
    Detroit, MI
    Double check driveshaft and leveling valve
    larry2903 and ChevyCam Thank this.
  4. Ridgeline
    22,794
    125,075
    Get the oil analisyed to see if it is going to crap out.
  5. AModelCat
    166,177
    5th wheel isn't sloppy?
  6. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Check engine mounts.
    ChevyCam Thanks this.
  7. 201
    201 Road Train Member
    12,915
    26,595
    Apr 16, 2014
    high plains colorado
    Man, I've driven some pretty tired 10 speeds, almost indestructible. Got to be something else.
    shatteredsquare and ChevyCam Thank this.
