Eaton 9 Speed splitter problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gunrtruck, Nov 3, 2017.
  1. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    That is a tight spot working through the shift boot hole, exhaust on the right and question if much can be done over the fuel tank on the left. Maybe able to work on it a little better with the driveshaft removed. Would not thank the trans would need to be removed. Sounds like your mechanic should do that for you. Good Luck.
    Bean Jr. Thanks this.
