EATON Auto trans, issued one with no manual
Discussion in 'Questions From New Drivers' started by speedyk, Nov 14, 2018.
  1. speedyk
    speedyk Road Train Member
    1,837
    2,472
    Apr 8, 2015
    Is there a way to manually shift one of these without it beeping continuously like the axles are locked? Which is what happens if I hit the Manual button. The only manual override thing that doesn't beep is Low, which holds it in 1st.
    If I just hit the arrows, it shifts, but then shifts on its own when it feels like it needs to. e.g. I can't hold it in 9th on a long upgrade, it will hunt to 10th, then back.
    Is there a way to reverse without lurching, just steady and slow? I've read about a creep mode with some autos but there is no manual in the truck, Low only works forward far as I can tell.
  3. STexan
    STexan Road Train Member
    14,963
    29,178
    Oct 3, 2011
    Longview, TX
    I’m in my first auto (Freightliner) going on about 14 months now. It has a Manual mode but not once have I ever used it or felt like I needed to use it. It easily allows for 1 gear up or down, on the fly while in auto. Not sure how Paccar (or whoever) does it
    speedyk Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    A manual mode button that does not allow you to up shift or down shift?
    A Bounce House tractor trying to back up on a automatic?
    IF the transmission is doing whatever it pleases rejecting your efforts at playing trucker on Manual, I bet the company has it configured software wise to refuse your efforts to hold a gear somewhere upgrade.
  5. larry2903
    larry2903 Heavy Load Member
    797
    1,005
    Oct 18, 2009
    On the trails
    Sounds to me like you need to visit the dealership to have some options changed. Creep mode and the alarm are both options that can be turned on or off.
    x1Heavy and speedyk Thank this.
  6. speedyk
    1,837
    2,472
    Apr 8, 2015
    Thank you @larry2903 I was pretty sure that I'd been in a cab where it worked that way. Programming it makes sense.
    x1Heavy and larry2903 Thank this.
  7. speedyk
    1,837
    2,472
    Apr 8, 2015
    This morning I noticed that Eaton is molded into the cover with the buttons. Changed thread title to reflect that. Now I need to find out if our shop can get in to it from their general service laptop.
    x1Heavy Thanks this.
  8. Espressolane
    19,334
    122,465
  9. SteerTire
    SteerTire Road Train Member
    1,414
    2,347
    Nov 5, 2018
    Behind the wheel
    Beeping is usually related to RPM being to low or high for the gear you’re trying to get to.
    The lack of holding a gear on a climb, is directly related to the settings. Yours is most likely set to economy mode. Frustrating as hell, I know. Gain 5 mph, upshift too soon, falls on its face, downshifts, loses that 5. Rinse and repeat.
    stwik, tscottme and speedyk Thank this.
  10. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
    A Freightliner I was in had a menu option for Economy Mode or Power Mode. I would sometimes pick Power Mode when getting through hills. I didn't feel like I needed to mess with Manual shifting.
  11. tscottme
    tscottme Road Train Member
    My Freightliner, I think it has an Eaton tranny, has a button to switch between auto and manual, but it's disabled in the computer. I pull tanker and the surge and the auto conspire to keep the truckbetween gears and searching for the right gear. I found a trick I use to prolong keepign it in the gear I want. My truck has a paddle shifter. Even though it's an auto I can force it into a lower or higher gear my moving the paddle shifter. Normally, you would force a shift by a quick pull-up or push-down on the paddle. My trick has me pulling it up or psuhing it down and constantly holding it in that position.
    For example, I'm fully loaded at 78,000 lbs and starting to pull a smaller hill. While the truck is a 12 speed, I know from experience 11th gear is the gear I want. Just before I start uphill I force and hold the paddle shifter down to get into 11th and hold it there throughout the climb. The tranny will override my effort if the RPMs get too low or too high. My trick prolongs the time I get in the gears I want. The tranny seems to be setup to maximize fuel economy. I would prefer my last truck with identical tranny and engine but the manual/auto switch was active. But you do what you have to do with what you have.
