Eaton Fuller 10SP grind when downshfting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MIg25, May 31, 2020.
  1. MIg25
    MIg25 Light Load Member
    73
    20
    Apr 10, 2020
    Fort Lauderdale - Florida
    Hello,
    I have a freightliner FL112 with a 10SP Eaton Fuller, when I am downshifting from 6th to 5th, I flip the switch it grinds very badly. Basically I have to stop the truck, flip the switch for it to drop gears.
    Any advise or input?
    Thank you.
  3. AModelCat
    165,530
    Sounds like a synchronizer issue.
    I'd start by checking the air pressure to the range cylinder. There's a regulator on the transmission that drops it down lower than air system pressure. Can't remember the exact PSI spec.
    There should be an air filter in there too that can get gummed up and make it lazy. There's also an exhaust port that can get plugged up and prevent air from dumping out of the range piston as well.
  4. MIg25
    73
    20
    Apr 10, 2020
    Is the air pressure range cylinder and the filter all mounted on the transmission itself? Where at?
    Indeed, when I am idling I flit the switch up goes fine, down it is a little lazy for sure.
  5. AModelCat
    165,530
    Should be somewhere on the transmission. Not 100% sure exactly as to where they'd be on a 10 speed.
    A5¢ and MIg25 Thank this.
  6. MIg25
    73
    20
    Apr 10, 2020
    I think this is the filter you speak of. See picture below with red arrow.
    pushbroom and A5¢ Thank this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    it should be hanging on back box, it unscrews and you can get water plus what/ever is caught in filter when you blow it out, its just a filter in the filter canister that un screws?
  8. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    Low air pressure usually makes slow shifts. If it actually grinds you need a syncro
    spsauerland Thanks this.
