I’ve got a 2006 international with a c-13 and a Eaton 10speed. The yoke seal is leaking and the bearings are worn(a lot of movement/play when you push on it). This is the yoke that comes out of the transmission not the rear-end. Can anyone give me a step by step process of how you’d replace it. Or maybe send me a video of how one is replaced. Thanks.
Eaton Fuller 10speed...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ralston Rosas, Apr 9, 2021.
Get the model number off the data plate and head to Eaton's website. They have just about all the parts books and shop manuals available for free download.
BoxCarKidd and spsauerland Thank this. -
Bad news is I'm about 98% sure you have to pull the auxillary section and partially disassemble it in order to replace the output shaft bearings.
spsauerland Thanks this. -
Make sure output nut is tight.
Hulld and BoxCarKidd Thank this. -
If you tighten the nut and the yoke has anything over almost no play you probably have bigger problems.
We use a 1 inch impact and a 2 & 3/4 socket to tighten them. If that takes all or almost all of the play out you should be safe to install a new seal and possibly a wear ring. Nut is considered a one time use item.
When yokes run loose for long periods of time the bearing races can spin in the housings. They are harder than the housings and housing wears. That requires replacement of the rear housing to correct.
Lots of Eaton Fuller Road Ranger info on line.spsauerland Thanks this. -
Recommended torque used to be 450-500 ft/lbs, but newer crimped style nut is 650-700 ft/lbs. I believe off top of head it's a K4122.
BoxCarKidd Thanks this. -
More than likely the yoke nut is loose mine did this awile back
