Eaton fuller 13 speed
Discussion in 'Questions From New Drivers' started by JsTrucking, Jun 26, 2012.
  1. JsTrucking
    JsTrucking Light Load Member
    50
    8
    May 15, 2012
    OKC, OK
    Hey guys, quick question.... Is there any tricks for shifting the higher range gears coming out of 5hi or 6hi into 6lo or 7lo? My downshifts and shifting through lower range has been great but going from 5hi to 6 lo has been dreadful. I hit the splitter valve back to low and then start my clutching to neutral and to the next low gear and I keep miss timing it. I'm thinking maybe I should wait til it's in neutral before hittin the splitter back to low since I think I'm releasing the gas early and it is causing the Rpms to drop out of sync... Guys at my job all float and so I'm getting no help... Yea I use the clutch... #### me.
  3. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    sorry i float as well.
    ask for a 10 speed.
  4. JsTrucking
    50
    8
    May 15, 2012
    OKC, OK
    That was helpful :/.... I understand the 13 just somewhere I'm faulting and me being so critical and analytical I'm stressing myself out more lookin for the solution
  5. Terrapin Flyer
    Terrapin Flyer Light Load Member
    243
    72
    Dec 3, 2011
    Annapolis, MD
    It sounds like you are trying to move the button back and move the stick at the same time. Once you go into 5th over, you can immediately put the button back. Nothing will happen until you break torque (releasing throttle, pushing the clutch, or both). This will set you up for the shift to 6th direct.
    You can shift 5 direct->6 direct->7direct->8 direct->8 over if load and terrain allows you. IE: Not using the splitter until you reach top gear. The splitter is overrated. Your are driving a glorified 9 speed.
    Run your tach to 1500rpm, which is about 300-500 higher than your low range. Go even higher going uphill.
    JsTrucking and CAXPT Thank this.
  6. ewill71
    ewill71 Heavy Load Member
    759
    234
    Oct 3, 2011
    mcgregor tx
    if your not pulling a REAL heavy load drive llike and 9 speed and use 13th as an overdrive
    you shouldnt have to hit every gear
    they guy above me posted as i was typing. its almost the same thing
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    That would be my only reason to have a 13 speed is that extra gear between the two top gears.
  8. JsTrucking
    50
    8
    May 15, 2012
    OKC, OK
    Well I haul gas and usually weighs around 78k.... And I was using the splitter before I started my shift but I guess it's gonna take time... And maybe if it's fairly flat I'll just not use it till the last gear or so.
  9. ewill71
    759
    234
    Oct 3, 2011
    mcgregor tx
    you will be ok doing as we all have said, the extra gears are for off road and real heavy pulling.
  10. JsTrucking
    50
    8
    May 15, 2012
    OKC, OK
    I appreciate all the responses! Thanks and I'll see how it goes not splitting the gears til 12/13.
  11. Allow Me.
    10,769
    12,593
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah Pardner, try shifting WITHOUT splitting the gears, like a normal 10 speed. Either up shift or down shift. Then when you get some confidence and a few miles under your belt, shift it as a 13 should be shifted.
