eaton fuller 18 speed need correcting
Discussion in 'Ask An Owner Operator' started by WTPHO, Dec 16, 2022.
  1. WTPHO
    WTPHO Bobtail Member
    4
    Jun 20, 2022
    I need help on my eaton fuller 18 speed. I just bought a 98 peter 379, cat 3406 with eaton 18 speed. What I'm trying to find out is that every time I spilt the gear, my rpm jumps up higher. Example gear 1234 switch up 5L (rpm 1600) spilt 5H (rpm jumps to higher by 200 rpm) and so on. I want to know is this correct or did the previous owner swap the spilt switch air hoses.
    NightWind Thanks this.
  3. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    What happens when splitting the higher gears?
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Ok so when you push the splitter forward it acts like it wants to split down if I'm reading it right?. What if you start with the splitter forward and move it back, does it split up?
    singlescrewshaker Thanks this.
  5. RockinChair
    RockinChair Road Train Member
    5,396
    14,516
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Congratulations on the new truck. When are we going to get to see pictures of it?
    When you push the splitter forward the RPMs should go down, and they should go up when you pull it back.
  6. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    Sounds to me like someone had the shifter knob off, and got the air lines mixed up when putting it back on.
    haycarter, Ruthless, abyliks and 6 others Thank this.
  7. WTPHO
    4
    Jun 20, 2022
    Yup, splitting it forward is like downshifting it (higher rpm). If I start with the split in the forward pos. and split it back pos. it goes into higher gear (lower rpm). I hope that makes sense.
    Big Road Skateboard Thanks this.
  8. WTPHO
    4
    Jun 20, 2022
    Thank You. I'll post some pic up soon. I was thinking that's the way the splitter gear should work.
    RockinChair Thanks this.
  9. WTPHO
    4
    Jun 20, 2022
    I try switching air lines on the shifter and all it did was release air from the shifter and it didn't split any gears. I thing the air line from the shifter going to the transmission is backwards on the transmission. so I'm going to switch the air line see what happens.
