Eaton Fuller 18 Speed Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jlittle0018, Oct 13, 2015.
  1. jlittle0018
    jlittle0018 Bobtail Member
    18
    Looking to buy a used Eaton 18 spd. Trans is out of the truck on the ground. When you put the shifter in gear, the output shaft will still turn. Is this normal???
  3. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Well is the input spinning?
    jlittle0018 Thanks this.
  4. jlittle0018
    18
  5. AModelCat
    164,906
    I should hope so. No different than if you were coasting in gear. Just as long as the input shaft turns at the same time while in gear.
  6. jlittle0018
    18
    Okay, I was thinking the back should turn with the front..
  7. AModelCat
    164,906
    Not sure what you mean. The output should turn regardless if the trans is in neutral or a gear. If the output turns when you spin the input and your in neutral, it could possibly be an issue. Could also just be a little bit of drag.
  8. jlittle0018
    18
    Awesome! That's what we were needing to know!
    Great help!!!
  9. jlittle0018
    18
    I haven't figured out the quoting yet on here. I am sorry!
  10. AModelCat
    164,906
    I should add that if the transmission is in the truck then no you won't be able to turn the output shaft when in gear because you will be trying to turn the engine over as well.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Confusing! Get someone who knows what they are looking at to knock the top off. Not much of the back section can be seen but that gets the pig out of the poke. It maybe possible to turn the input without the output turning when the shift lever is in gear because there is no air to hold the range and deep reduction engaged. I like the new look Northern. Did you get the frame finished?
