Eaton fuller bellhousing interchangability
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gambino1994, Mar 15, 2022.
  1. Gambino1994
    Gambino1994 Light Load Member
    187
    103
    Jan 22, 2009
    causing a situation
    Currently have a wore out rtx16710c, will that bellhousing work on a rtlo16713 trans. Also does a halo trans need a halo bellhousing?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Should work fine, Halo needs halo clutch cover.
  4. W923
    W923 Road Train Member
    1,426
    4,421
    Feb 28, 2022
    Bellhousing will work both are 167xx
    Does your current trans have a pump
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    There is a plug kit deal for a halo trans and a non halo housing. It will work.
    Gambino1994 Thanks this.
  6. Gambino1994
    187
    103
    Jan 22, 2009
    causing a situation
    Not sure on pump, I have an air cooler for trans oil in front of the radiator
  7. W923
    1,426
    4,421
    Feb 28, 2022
    Then you have a pump
    So if you’re new tranny does hook it up otherwise cap the lines or remove it
  8. Gambino1994
    187
    103
    Jan 22, 2009
    causing a situation
    Thanks Just bought a used 16713a should be here tomorrow unless it falls out of the fedex truck comin thru Chicago
  9. W923
    1,426
    4,421
    Feb 28, 2022
    Possible
    Illinois roads are rough as …
