ECM programming for N14
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PaulE, Oct 27, 2009.
  1. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    A friend is looking for a source to program ecm on a 95 red head. does not want to change hard parts or use PP box. moderate hp increase and maybe some mpg. I know PDI is one option. anyone know of others?
  3. Heavyd
    Heavyd Road Train Member
    7,821
    6,273
    Feb 4, 2009
    First, you will have to get the CPL number off the engine and see how high you can go without physically changing any parts.
  4. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    true if you are by the book a ECM doesn't know what N-14 its hooked to you can program any cpl you like into it all factory injectors was good for 460 all red heads is good for at least 500 I'm not sure what was swapped for the 525 setting
  5. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    I will check on CPL. could be wrong but thought a red head was 460-525hp its a 500 now.
  6. Mack427
    323
    93
    Jan 22, 2009
    seems like ive seen a few 435 red heads ECM probley has the 525 setting but if it doesn't have a trans rated for the torque all the shops I have been to always told me no, I did buy a ecm that was a celect factory 370 that was uprated to 460 and 1650lb of torque put it on a n-14 330 with a 1400 series 9-spd, motor ran so much better alot more timing never had any drive line issues
  7. CaterpillarWrench
    CaterpillarWrench Light Load Member
    188
    49
    Nov 11, 2008
    Wrenching feverishly
    If it's a 500 it might be 1650 torque,that could be uprated to 525 1850 torque,that's a nice increase with the torque.Also,Illinois Dyno Center claims to be able to get even more out of them with ecm tuning.
  8. Heavyd
    7,821
    6,273
    Feb 4, 2009
    Sometimes they will limit the max RPM. For example, 500 hp at 1800, VS 525 at 2100. Reprogramming allows the max rpm to increase from 1800 to 2100 to get the hp increase.
  9. cumminspwr600
    cumminspwr600 Light Load Member
    62
    6
    Dec 16, 2008
    pittsburgh,pa
    paule is it a celect plus if so i might be able to help if it is a plus pm me i will try to help
  10. cumminspwr600
    62
    6
    Dec 16, 2008
    pittsburgh,pa
    paule i cant pm i dont have enough post if you dont mind pm me your email address i will tell you a little info
  11. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    If i remember correctly, you need 50 posts to PM. Reply to me 12 times and i think you will have it. I cant remember what day it is... would you post me an answer.......:biggrin_25525:
    cumminspwr600 Thanks this.
