ECM Question Series 60
Discussion in 'International Forum' started by 9200 IH, Jul 5, 2018.
  1. 9200 IH
    9200 IH Bobtail Member
    35
    5
    Jul 26, 2014
    Took my batteries out to clean and check water. Made myself a sketch of the cables and wire hookups. I forgot one wire on the sketch. It is a white wire that changes to 4 white wires up inside the harness. It goes to the ecm . If you were holding ecm in your hands looking at it head on the connector would be in the top right corner. I am pretty sure it goes to negative. I did a bunch of searching on line but didn't find anything to make me 100% sure.
    1996 series 60 Detroit Diesel 370/430hp
    Truck build date is November of 1995
    Pretty sure its a DDEC3
    9200 IH
    I posted this on the O/O site to. I gotta get it going for the morning.
    Thanks Mike
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    On the connector there should be 5 wires. (2) red (3) black. The 3 black (ground) all in a row top to bottom. The 2 red (battery) in row top to bottom of connector. Hope that makes sense.
    9200 IH Thanks this.
  4. 9200 IH
    35
    5
    Jul 26, 2014
    Yes it does make sense. Only difference my grounds were white. Got it running.
    Thank you very much
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Yes, they are ground. International ground wires are white.
    Accidental Trucker and 9200 IH Thank this.
