ECM Series 60 Question
Discussion in 'Ask An Owner Operator' started by 9200 IH, Jul 5, 2018.
  1. 9200 IH
    9200 IH Bobtail Member
    35
    5
    Jul 26, 2014
    Took my batteries out to clean and check water. Made myself a sketch of all the cable and wire hook ups. I forgot to mark down one wire. It is a white wire, it goes up into the harness and changes to 4 wires and then it goes into the top right hand connector of the ecm if you were looking at it head on. I am pretty sure is goes to negative but not sure. Did a bunch of searching online couldn't find anything to make me 100% sure.
    Any help would be great
    Thanks Mike
  3. 9200 IH
    35
    5
    Jul 26, 2014
    1996 Detroit Diesel Series 60 370/430 hp
    International 9200
  4. 77fib77
    77fib77 Road Train Member
    11,687
    77,170
    Jul 7, 2010
    St Louis
    Picture of it?
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    White tends to be ground (negative) in Freightliners. An ohm meter should confirm that it is grounded to the chassis.
  6. 9200 IH
    35
    5
    Jul 26, 2014
    Thank you for your reply. My grounds are white too. The stuff I found online showed these 4 wires to be black on a Detroit diagram. I got it running. Everything is good.
    Thank you for your help
    Mike
