ECU
Discussion in 'Experienced Truckers' Advice' started by AriGab, Dec 2, 2024.
  1. AModelCat
    165,166
    The engine only makes so much power. You might have more gear reduction at the axle with 4.10's but you're going to be in a higher gear in the transmission so you're pretty much in the same place all said and done.
    Oxbow, AriGab and Ruthless Thank this.
  3. AriGab
    AriGab Light Load Member
    62
    27
    Feb 3, 2023
    Do you think 4.10 gears are not necessary? Would 3.90 gears be better? Trying to find the perfect balance
  4. 062
    062 Road Train Member
    6,349
    34,014
    Oct 20, 2013
    @Goodysnap may be able to help with the speed limiter question.
    AriGab Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,614
    13,333
    Jul 6, 2009
    A 20 year old truck. Speed could have been changed. I think the speed limit may have been lower in 2005.
    The ecu settings can be changed.
    I once drove an 05 w900 that was a swift truck. It was set for 65. Untill it got the ecu reflashed. It had no limits after that. Except maybe the rpm.
    Keep in mind it may have a password. Cummins had to use a zapper software to crack the password before they could reflash it.
    Lonesome and AriGab Thank this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,781
    9,221
    Jul 12, 2017
    On new truck orders the speeds can be set to the customers request upon delivery. You can have the speeds changed to what you wish. Cummins engines have a max speed setting of 125. Note- most heavy spec vocational trucks with the big rubber on steers- 385 and 425 are max speed rated at 68mph. Most dealers will not set the speeds above this for liability/ safety reasons.
    Lonesome, Oxbow, 062 and 1 other person Thank this.
  7. Ridgeline
    22,758
    124,255
    Have you actually talked to the dealer?
    the dealer is better to talk to than people on any forum.
    Most dealers have ordered a few trucks and know how to gear them and how to have the truck setup for you, the customer.
  8. buzzarddriver
    3,859
    11,719
    Feb 1, 2011
    Dallas, TX
    Honey buckets should be limited to 45mph.
