Ecu128 SID001 FAIL00
Discussion in 'Freightliner Forum' started by Christops, Nov 11, 2020.
  1. Christops
    Christops Bobtail Member
    14L series 60 detroit Columbia 2006
    I've searched and searched to no avail. The check engine light come in and out sometimes stays on for longer periods than others. Sometimes after getting off the road and idling is stays on for a hot second. Does anyone have any idea what it could be?
  3. AModelCat
    164,927
    If you got this fault off the on-board screen in the cab then I believe its just telling you the engine ECM has an active fault. You'd more than likely need to connect a diagnostic program to the truck in order to pull the actual fault code that's active in the engine ECM.
