Egr cooler problem ????
Discussion in 'Volvo Forum' started by habfleet, May 30, 2012.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    Have a 2005 VN with D12 engine.Truck uses 2-3 gals coolant daily. No external leaks,no coolant in exhust pipe no white smoke out of stack while operating.Apprears there maybe oil in the resevior tank.Driver reports that truck will intermittenly loose power during the day.There is a lot of oil emmittening from the clamp in front of the reed valve which connects the air tube to the mixer box. I was thinking possibly a bad EGR cooler but the oil is throwing me off. ANY IDEAS. THANKS IN ADVANCE
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    oil-coolant heat exchanger, located on pass side of cyl. block
    habfleet Thanks this.
  4. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Pablo how is the oil getting up into the reed valve ? From the oil cooler Thanks for the help
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really you may have a combination of problems. EGR cooler + heat exchanger.
