EGR valve fix on Volvo D12D
Discussion in 'Volvo Forum' started by bravoo67, Mar 2, 2013.
  1. bravoo67
    bravoo67 Light Load Member
    257
    35
    Mar 15, 2012
    Brooklyn NY
    Has anyone tried cutting the moving part on the valve so the electric motor would still work without actually closing/opening it?
    And then welding it so the fumes wouldnt go through the valve?
  3. Tallman67122
    Tallman67122 Light Load Member
    138
    74
    Apr 2, 2012
    Pine Hill, NJ
    go ahead and try it but when you get hauled into the inspection bay and they do a thorough inspection and find what you did you will wish you just got it repaired. More then likely your truck will be towed, you will be fined a hefty amount and then you could face license suspension too. Oh and how do i know this? I was a former state trooper awhile back who did inspections. We know what to look for. Now as a driver i know what not to do.
  4. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    So you open the EGR valve and check what's inside?
    I'm glad I don't live in USA.
  5. sbaumann14
    sbaumann14 Road Train Member
    1,244
    1,446
    Sep 1, 2010
    Rhinelander, WI
    don't know how they can check without opening up the EGR valves. I would say they can just use a "sniffer" on your exhaust, but with all the different year trucks still allowed to run NJ, dont know how they could do it
  6. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    Smoke test is easy ,they can do that, but without EGR engines are cleaner so no problem. I have never heard about NOx testers outside engine laboratories so it's hard to believe they have one.
  7. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    Not that I would ever bypass the EGR system on a diesel engine....I think it is a complete waste of time and effort. But there is absolutly no way this would be checked on a roadside inspection, or weigh station. You simply cant tell from just looking at the outside of the EGR valves (on a D12 volvo anyways).
  8. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    No way they could check without removing the egr but there is a few sensors that are part of the egr systems and it might sedate the truck I stead of welding them u could just unplug it its the same effect and a lot cheaper but I wouldn't suggest doing either one
  9. bravoo67
    257
    35
    Mar 15, 2012
    Brooklyn NY
    Has anyone heard of replacing barometric air sensor or something like that with resistors/diodes so EGRs wouldnt open?
  10. Jetsr6
    Jetsr6 Light Load Member
    131
    46
    May 20, 2011
    Mechanicsville, VA
    Check out pdqperformance.com. They can kill the cycling part of the EGRs. So u can remove the EGRs from the exhaust but they still have to be plugged in to the ECU. They also have a Blixxton 200 Volvo box that adds more power. ;)
