ELD issues / DOT tolerance of issues
Discussion in 'Questions From New Drivers' started by Kuda1988, May 8, 2019.
  1. Kuda1988
    Kuda1988 Bobtail Member
    hi I’m a relatively new driver
    The truck I’m running seems to have an issue with the ELD , I cannot connect to it on my phone, so therefore it doesn’t calculate my driving distance , driving time, etc.
    I have been manually entering the info ( on KeepTruckin) , I assume this is not tolerated by DOT and I could be fined, correct? Any ideas on what the issue could be?
    Will they really fine you up to 10,000 if there’s a violation or if you #### up your log??
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    you suppose to use a paper log if elog is down. i knew someone that wrote there hos on note book paper. that didnt workout to good.
    tscottme and ibcalm19 Thank this.
  4. Numb
    Numb Crusty Curmudgeon
    4,344
    10,322
    Jan 30, 2012
    Charlotte, N.Carolina
    your truck's ELD needs a phone to work??
    it's not a stand alone unit hooked to the trucks ecm?
    use paper logs, until fixed.
    tscottme Thanks this.
  5. Truckermania
    Truckermania Road Train Member
    1,185
    1,804
    Oct 13, 2011
    Sturgis,SD
    As noted you should use paper logs until fixed. I think you only have 14 days to get it fixed but I could be wrong. I have been inspected 3 times since the implementation of elogs. 2 of those times they did not ask for my logs or even mention them. The other time he basically just saw that I had an elog and glanced at it, called it good and moved on. Honestly I think most DOT out there are more clueless about how elogs work than we are.
    Tombstone69 Thanks this.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    In the past I have had dot tell me that it was legal to do your logs on a brown paper bag,not sure how true that was.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Is your phone hooked up to the ELD module for Keeptruckin with a USB connector? The administrator for your company needs to create an account for you and your truck so your phone will pair up with the ELD. Call Keeptruckin support if you can't figure it out. They're pretty good getting it done for you.
    If DOT checks your logs and you don't have a paper back up with the ELD not working, you're screwed.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You better have your last 8 days on paper logs and pronto fix the ELD fast.
    Because OOS is the least of your concerns.
  9. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    brown bags are a great idea.
  10. Espressolane
    18,733
    117,503
    You only get 8 days, after that you have to apply for an extension. You need to apply for extension before the 8 days are up.
    Call KeepTruckin help line. They will figure out what’s going on and get things worked out.
  11. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Men you know something keep it secret. this is not a right place to share your secrets.
