ELD to Paper Logs help needed.
Discussion in 'Experienced Truckers' Advice' started by Barricadebouncer, Feb 20, 2024.
  1. Barricadebouncer
    Barricadebouncer Light Load Member
    145
    166
    Apr 11, 2022
    Started with a new carrier. They use paper logs. Since I’ve never used a paper log, EVER, I could use some training.
    Can someone point me to a good resource that explains how to fill them out.
    Thanks in advance.
    tscottme Thanks this.
  3. ‘Olhand
    ‘Olhand R.I.P.
    6,750
    16,655
    Jan 18, 2011
    Don’t overthink it….Log it like you did it….same as eld…
    Stop somewhere…draw a line to either on duty/off…before you pull out…draw another line back to drive
    ONLY difference is…you are now working in only 15 minute increments….Rule of thumb has always been
    More than 7minutes…got to next 1/4 hour
    Less than 7 use previous 1/4
    Other than that you’ll hafta show at least a full 1/4 hour for pre/post trip…fueling…ckg on at stop..whereas an eld allows for actual time
    Don’t be afraid to come back and ask if you have specific questions
    Youll be fine
  4. BigR
    BigR Road Train Member
    4,149
    38,576
    Dec 28, 2008
    Shawnee, OK
    Pretty simple, just draw a line through the appropriate duty status on the grids. At the bottom directly under the duty status lines draw a line to flag each duty status change, notate the city and state, also what it was for, fuel,unloading, ext... add your hours at the end of the day, if there aren't 24, ya did something wrong!.... fill out every field, if it doesn't pretain to yo put N/A. Don't forget to sign it at the end of the day... I'm sure there's probably youtube videos that can give you a visual of what it should look like.... do they not teach this in truck school anymore?...
    Barricadebouncer Thanks this.
  5. Numb
    Numb Crusty Curmudgeon
    4,477
    10,891
    Jan 30, 2012
    Charlotte, N.Carolina
    no directions on the back of the book?
    W923, drh72, Diesel Dave and 1 other person Thank this.
  6. xsetra
    xsetra Road Train Member
    5,209
    7,162
    Aug 21, 2011
    Now you have to keep track of your clocks. Double check your addition and subtraction. Easy to make a 1/4 hour mistake.
  7. MacLean
    MacLean Road Train Member
    1,385
    4,118
    Sep 12, 2017
    Download Motive and create a free account. It’s very easy.
  8. tscottme
    tscottme Road Train Member
    YouTube usually has videos on everything. Some are good.
  9. ilovetruckz
    ilovetruckz Light Load Member
    242
    339
    Oct 6, 2021
  10. Barricadebouncer
    145
    166
    Apr 11, 2022
    Looks like what the Dr ordered.
  11. Barricadebouncer
    145
    166
    Apr 11, 2022
    I’ll find out when I get one. Still doing orientation.
    Numb Thanks this.
