Electric blanket battery use
Discussion in 'Experienced Truckers' Advice' started by MJ1657, Jan 28, 2012.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I'm thinking of getting a 12 volt or 110 volt electric blanket for those nights when its not real cold.
    Has anyone used one and do they eat up to much battery to start my truck in the morning?
  3. ZippyNH
    ZippyNH Medium Load Member
    408
    121
    Aug 8, 2010
    Southern NH
    Do you have opti idle? If you do the lowvoltage monitoring will restart the truck to recharge the batts....but still less idling then having it in temp control mode.
    I would multiply the fuse rating on the 12v blanket by 12 to get a wattage or do the amphour calculation for how much it will draw...
    Will not be very accurate..thermostatly controlled, so draw will vary with temp...more when cold....less when warm....and batt capicity varries from new....and with temp.
    i'm thinking on a cold morning, when you need good batts, you may have issues....so get a sleeping bag!!!
  4. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    No I don't have opti idle.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I had one for a couple years. I never had a problem starting in the morning.
  6. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Dont know much about 12v blankets but dont most electric blankets draw a consistent amount no matter what the temp is?
  7. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    They only draw current when there is a need for the blanket to be heating, electric blankets switch on and off to maintain a temperature. If the heat doesn't switch off, any heating device will get things too warm.
  8. rockee
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Thanx. Lol I should have realized that because I hear mine cycling on and off every night almost and.............it makes sense
