Electrical fault
Discussion in 'International Forum' started by Tulile419, Jul 19, 2018.
  1. Tulile419
    Tulile419 Bobtail Member
    I have a 2010 Pro star with a ISX the truck every about 9000 miles will give me electrical fault and all my gauges on the right side of the dash will come off when i plug the ecu to get a diagnostic will give low oil preasure sensor in which i have change 2 times already but when i change all the filters it will go away for another 8 to 9000 miles. Ty
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Ok, you have more than one problem here. If you are getting low oil pressure, which is corrected by changing oil, then that is a mechanical problem with the engine that needs to be looked at. The electrical fault is usually a communication problem between electronic modules. I recommend getting the truck scanned with Diamond Logic Builder software and Cummins Insite to see what codes are getting logged.
    blairandgretchen Thanks this.
