Can anyone identify this part, I need to know what it does and what it controls and can it effect my gauges etc... 1992 peterbilt 379
Electrical issues need help
Discussion in 'Peterbilt Forum' started by loginix, Nov 30, 2016.
Starter box, once you trip it, it should crank the starter. That would be my guess.
It's very hard to guess a box without following the heavy wires to wherever it feeds.loginix Thanks this. -
It's a salinoid big wires should go to the batteries and the started small wires to the ignition switch
That's a switch (or relay) that gives power to starter solenoid when you press the start button
Thank you all.
If you need to replace it, look for a "starter Mag switch".
