Electrical ?
Discussion in 'Intermodal Trucking Forum' started by down south, Sep 28, 2017.
  1. down south
    down south Bobtail Member
    37
    6
    Nov 4, 2016
    I have 2007 9400I c15 acert I got to noticing when I accelerate I notice volt meter drop checked voltage coming into fuse box 13.8 volts pulled alternator belt does same thing on acceleration also meter on cb goes up when you accelerate let off throttle it drops any ideas
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    What? Try explaining that again, with punctuation please.
  4. down south
    37
    6
    Nov 4, 2016
    Volt gauge drops when accelerate . Volt gauge returns to normal when you let off throttle. Then removed belts to eliminate alternator it still does I also noticed it in CB meter except when you give it throttle RF meter goes up. I checked with external volt meter at fuse box power where power comes in Voltage steady.
  5. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Ok. Removing the belt and loading the alt will cause a V drop then back to available V indication, and then diminish as battery V dwindle. The RF meter on the CB, I can only guess it is due to the unsupported load. I am puzzled why you removed the belt to check anything. Check the output from the ALT at the back of the ALT, at idle and under load at rpm, then check it at the batteries and check the connections. V should increase with load and rpm, if it is dropping off, check for a poor case ground or ground wire connection. If that is OK, then it may be that the brushes inside the ALT are worn out it is time for a rebuild/replacement.
  6. down south
    37
    6
    Nov 4, 2016
    Simple with batteries fully charged the V drop in my volt meter was still 13V so I eleminated the alternator being problem
  7. Dave_in_AZ
    424,944
    Check and clean your grounds. Especially the terminal ends on the cables / wires. By that I mean the wire itself where it comes into the connector.
  8. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    The rf meter is going up due to poor grounding. Is the cb grounded to the power studs? If so, try putting an inline filter or going straight to the battery. And as mentioned above, clean and tighten all your grounds. The batteries fully charged should be 12.6, the alternator should really be between 13.4-14.2 charging at normal rpms. Honestly, 13.8 would be better for the low range. Your voltage regulator may be getting ready to go inside the alternator.
  9. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    I'm not good with posting links,so use the search in the top right corner. Put in "voltage drop" one on the first page,one on the second page to point you in the right direction.
