Emissions Maintenance on X15
Discussion in 'Ask An Owner Operator' started by Pamela1990, Dec 14, 2021.
  1. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    This coming year I am getting 4 new trucks, they all have the Cummins X15.
    What parts of the emissions system need maintenance, and how often.
    This is new territory for me.
    Thanks
  3. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    The main thing is do not put DEF into fuel tank, it should be fine otherwise if you follow manufacturer's instructions)
    BennysPennys and Pamela1990 Thank this.
  4. Oxbow
    Oxbow Road Train Member
    13,680
    141,878
    Nov 24, 2015
    Are all of your current trucks pre-emission?
  5. AModelCat
    164,925
    Normally you drive into pot hole and that stuff falls off.
  6. MACK E-6
    50,097
    239,038
    And don’t put fuel in the DEF tank like one dumb-### I work with.
  7. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    Yes.
    BennysPennys and Oxbow Thank this.
  8. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    That must be some wild pothole.
  9. Oxbow
    13,680
    141,878
    Nov 24, 2015
    I got nuttin.
    We do have DPF on a dozer, but other than that no experience whatsoever on anything newer than a 2000 truck.
  10. AModelCat
    164,925
    Biggest thing with the emission engines is to make them work. They like heat. DEF degrades over time. With your type of operation I'd buy it in barrels, rather than from the pumps. At least you know the quality is good if you test it when you unseal it.
    D.Tibbitt, Dino soar, bzinger and 5 others Thank this.
  11. Kyle G.
    Kyle G. Road Train Member
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    I know a guy who did that. Apparently he didn’t know the DEF had its own pump? I still don’t understand how he managed to fit the diesel nozzle in there, but maybe I don’t want to know.
    Dino soar, Pamela1990 and BennysPennys Thank this.
