HI, My ENG is VOLVO D13 2014
I got 2nd same problems on ENG this morning(10/18/21).I started my eng and running for about 3min and then shot down after 3min.so I tried to start a fiew times but not start ,just cranking, so I waitted about 40min,and i tried again to start ,NOw ENG is running and then Allday is OK after that(many times turn On and off)
This issue happened 2weeks ago ,Everything is same as today.
Could you let me know a reasons or how to fix ,thank you very mucn
ENG problems
Discussion in 'Volvo Forum' started by sammaxlee, Oct 18, 2021.
No way to help you without you giving us codes.
truckdriver31, Bean Jr. and LoneRanger Thank this. -
i don not have any code ,any check ENG light and notice light
Does this truck have a battery cutoff switch? When was the last time it was replaced? It might be something to look at.
yes my truck has a battery cutoff switch on the left bottom of driver seat,It didn't get replaced for last 2years,I cutoff everyday afterwork,after work, could you please explain how it has to do with my problems, and please let me know what I have to do ,I appreciate it your help,I am Korean so l can write down a limited english
I bought this truck 2yers ago.I didn't change a battery cutoff switch
So let,s chang this first ? -
Ok first check the battery cables and make sure that they are tight.
The battery switch goes bad over time. It can cause weird things to happen. If you drive in areas that use salt or brine the switch should be changed or eliminated. -
Thank you for your quick reply first, I'll ask you one more question, could you read the initial question one more time, and even after the engine is turned off, the battery power is connected and cranking is possible.It's just that we're out of fuel, and we've checked all the battery connections and tied cable, Is there any other reason?I appreciate it again
The long cranking could be another issue but withoit seeing the truck I don't want to say it's injectors. You should get it properly diagnosed. That way you get it fixed the first time.
The battery cut-off switch isn't that expensive and should be easy to replace on your own. -
thank you very much for your advise, Anyway I have no problems on ENG to start so far, But I will replace battery cut off switch first
