Engine air filter 1 differential pressure ? Where to start ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon0928, Nov 11, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    Have code for Engine air filter 1 differential pressure Spn 107 fmi 3 sa 49. Tried looking this up on Google and could not find anything at all. Any idea what this is for and how to fix it ?
  3. Brandon0928
    184
    105
    May 14, 2022
    2018 579 Peterbilt cummins x15 efficiency series
  4. Arctic_fox
    4,552
    25,867
    Sep 16, 2016
    Could be a couple things. Most likely is a failed sensor. Next is if your using an aftermarket filter that could be an issue amd causeing too much pressure. Could have a bad throttle valve, clogged intake and so on. Past that you start getting into stuff like wireing and so on.
    Best bet is to just take it to a shop and have them pull the codes and run diagnostics unless you have the software and/or equipment to test for leaks or clogs and such.
    Brandon0928 Thanks this.
