Engine/alternator noise on radio
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Buckeye91, Oct 15, 2013.
  1. wilfredbacon15
    wilfredbacon15 Light Load Member
    277
    50
    Sep 29, 2013
    Manila, Philippines
    I will remember those advices because maybe someday I can used them for some solution. :)
  3. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
  4. MsJamie
    MsJamie Road Train Member
    If you're plugged into the Aux jack, and it sounds fine when on battery but you get a lot of noise when on the charger, you have a condition known as a "ground loop".
    The easiest way to eliminate the noise is to use an isolating audio cable.
    I use one from Kensington. It lists for $20, but you can easily find them cheaper.
    Amazon: http://www.amazon.com/gp/aw/d/B0031U1ATQ
