For the past 8 months I've been driving a 2017 Freightliner Cascadia. I've become so accustomed to the DT12 engine brake (control positioned on the steering column) that I'm a bit nervous about the prospect of switching to a T680 Paccar (engine brake control positioned on the dash). Is it as cumbersome to reach/apply as it appears in photos? Have to reach all the way to the dash each time I want to use it? I just wonder how quickly my muscle memory will adjust to that change. I'm sure there are many other things which are different between the two trucks, but that one is what's got me thinking. I am still a newbie at driving -- 14 months total between two stints as a truck driver -- so my experience with differing transmissions/trucks is limited. I submit this post as I'm considering applying to a company w/ mostly T680's.
Engine brake difference between DT15 and Paccar (muscle memory).
Discussion in 'Questions From New Drivers' started by ruudhompsor, Aug 3, 2018.
correction: DT12
I should probably add that I use the engine brake a lot. Probably too much, but it works for me.
Depends on transmission in t680 the new ones with the 12 speeds have a column mounted engine brake... either way if your coming from a DD15 the brake will be weaker than the shaker .. if your current truck is a DD13 it will be similar .. on my 2015 i find it in a nice position however I’m 6’4” so I have a good reach
ruudhompsor Thanks this. -
I love the stalk on my Volvo. Unless I am really loaded I don't even have to touch the brakes.
I think you're over thinking the position of the engine break switch.
stwik, Samuelh, ruudhompsor and 1 other person Thank this. -
Who turns the jake switch on/off every time? Just leave it on and use the throttle pedal to turn it on/off.
stwik and ruudhompsor Thank this. -
I'm in an International with ISX, jake level switch on the dash. Has on and off switch on the steering wheel. Took all of a few times to get used to it.
I leave it on and just use the throttle peddle and the dash switch.ruudhompsor Thanks this. -
Switching from a Freightliner to a T680, you're in for a BIG surprise! The Paccar engine brake SUCKS! It sucks so bad that I sometimes have to rethink my route depending on weight. I frequently am headed west on I-40 and have to get down to I-8. My company's suggested route is taking I-17 from Flagstaff down to Phoenix. Those are some long, high grades to go down and if my load is over around 25k I go down I-25 instead from Albuquerque. It only took me one time going down I-17 with a 40k+ load to learn how terrible of an idea that was in my new T680.
After 8 months of being in a different truck, I still reach over to switch the jake off occasionally.
